Print at Sep 27, 2026, 7:50:35 AM
Posted by efferre at Jan 7, 2018, 5:19:03 PM
opengl issue with Linux
I am trying to run SweetHome3D but I get the following error:
com.jogamp.opengl.GLException: J3D-Renderer-1: createImpl ARB n/a but required, profile > GL2 requested (OpenGL >= 3.1). Requested: GLProfile[GL3bc/GL3bc.hw], current: 3.0 (Compat profile, compat[ES2], FBO, hardware) - 3.0 Mesa 17.2.7
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:440)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4602)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2376)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2)
X11Util: Open X11 Display Connections: 2
X11Util: Open[0]: NamedX11Display[:0, 0x7f0a9c009590, refCount 1, unCloseable false]
X11Util: Open[1]: NamedX11Display[:0, 0x7f0a9c121890, refCount 1, unCloseable false]
Here is the result from glxinfo:
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
Extended renderer info (GLX_MESA_query_renderer):
Vendor: X.Org (0x1002)
Device: AMD RV770 (DRM 2.50.0 / 4.14.12-gentoo, LLVM 4.0.1) (0x9442)
Version: 17.2.7
Accelerated: yes
Video memory: 512MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 3.3
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.0
OpenGL vendor string: X.Org
OpenGL renderer string: AMD RV770 (DRM 2.50.0 / 4.14.12-gentoo, LLVM 4.0.1)
OpenGL core profile version string: 3.3 (Core Profile) Mesa 17.2.7
OpenGL core profile shading language version string: 3.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
GL_AMD_performance_monitor, GL_AMD_pinned_memory,
GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_separate_shader_objects,
GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,
GL_ARB_shader_stencil_export, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_float, GL_ARB_texture_mirror_clamp_to_edge,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
GL_ATI_blend_equation_separate, GL_ATI_meminfo, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_blend_equation_separate,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,
GL_KHR_no_error, GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_NVX_gpu_memory_info,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
GL_NV_texture_barrier, GL_OES_EGL_image, GL_S3_s3tc
OpenGL version string: 3.0 Mesa 17.2.7
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
GL_APPLE_packed_pixels, GL_ARB_ES2_compatibility,
GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,
GL_ARB_get_texture_sub_image, GL_ARB_half_float_pixel,
GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shader_stencil_export, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
GL_ATI_fragment_shader, GL_ATI_meminfo, GL_ATI_separate_stencil,
GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_gpu_program_parameters,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset,
GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NVX_gpu_memory_info,
GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 17.2.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
OpenGL ES profile extensions:
GL_APPLE_texture_max_level, GL_EXT_base_instance,
GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_color_buffer_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_copy_image, GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,
GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
GL_EXT_frag_depth, GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra,
GL_EXT_separate_shader_objects, GL_EXT_shader_integer_mix,
GL_EXT_texture_border_clamp, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_rg, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,
GL_MESA_shader_integer_functions, GL_NV_draw_buffers,
GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
GL_OES_EGL_image_external, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,
GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,
GL_OES_surfaceless_context, GL_OES_texture_3D,
GL_OES_texture_border_clamp, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_vertex_array_object,
GL_OES_vertex_half_float
The OpenGL core profile is 3.3 while the compat and ES profiles seem to be only 3.0. I am using Mesa 17.2.7. Any ideas?
Posted by Puybaret at Jan 7, 2018, 9:25:50 PM
Re: opengl issue with Linux
Did you try the other script SweetHome3D-Java3D-1_5_2 of the installer version available for download?
Posted by efferre at Jan 8, 2018, 10:59:13 PM
No, I am installing from source because trying to package SH3D for Gentoo (see also https://bugs.gentoo.org/209696). I have successfully built from source but it seems that SH3D or jogl, when running, are asking for a opengl compat profile 3.1 while the driver is offering only 3.0 (but the core profile is 3.3). But I don't OpenGL at all so it's only a guess.
I am using:
* j3d-core-1.6.0
* jogl-2.3
* gluegen-2.3
If I set MESA_GL_VERSION_OVERRIDE=3.1, then SH3D starts but I don't know which part of the applications uses compat 3.0
Posted by efferre at Jan 10, 2018, 10:23:24 PM
Ok, I have finally managed to run SH3D using j3d-core-1.5.2 so I doesn't work only with j3d-core-1.6.0. Emmanuel, do you confirm that SH3D requires max j3d-core-1.5.2?
Posted by Puybaret at Jan 11, 2018, 12:16:51 AM
Sorry, I can’t confirm anything. If I provide two versions of Java 3D in Sweet Home 3D, it’s because I received some reports about some users who needed Java 3D 1.6 and others who still needed Java 3D 1.5.2. I experienced it was true on my own Linux box running different versions of Ubuntu.
Posted by efferre at Jan 13, 2018, 3:06:16 PM
I guess it depends on java3d then, they should have changed something from 1.5.2 to 1.6
Posted by efferre at Jan 23, 2018, 10:52:33 PM
I have finally solved my problem. It was an issue of jogl-2.3.2 not supporting correctly the mesa version I have installed (17.2.7), basically jogl-2.3.2 is not correctly recognizing the mesa driver for opengl support. You can read more details here:
https://github.com/hharrison/java3d-core/issues/23
http://forum.jogamp.org/problem-using-jogl-2-3-2-on-linux-tc4038557.html
where there is a patch needed to fix the issue. Anyway the problem will be definitely fixed with the future jogl-2.3.3 version.
On my system then, I am able to run SH3D both with j3d-core 1.5.2 and 1.6 :-)
