Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to lock a single wall,not all walls? |
| Print at Sep 25, 2026, 11:19:14 PM | |
| Posted by peterweaver at Jan 10, 2018, 10:50:55 PM |
How to lock a single wall,not all walls? Hi there, I am new here When I draw a wall, how can I lock a single wall? Is it a function similar to ortho in Autocad, where I can draw a straight walls? How can I trim two intersecting walls? Cheers |
| Posted by Puybaret at Jan 11, 2018, 12:43:12 AM |
Re: How to lock a single wall,not all walls? In Sweet Home 3D, you can lock all walls or unlock them, but you can’t lock individual walls. I don’t know Autocad so the only thing that "straight" walls makes me think about in Sweet Home 3D context, is its magnetism that you may enable or disable in the preferences to help you draw walls at an angle multiple of 15º or at any angle. See help about magnetism for more information. I’m not sure to fully understand what you mean by "trimming". Did you try the recently added menu item Plan > Join walls? Is it what you look for? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterweaver at Jan 11, 2018, 10:47:41 PM |
Re: How to lock a single wall,not all walls? Hi there, Thanks for your response. I have meant trimming about cut etc. I know about locking all wall,but if you add another item to the wall,then the wall is unlocked. I am trying to learn sweet home 3d ,just to be able to prepare a visualisation 3d for rooms,flats,houses etc. I hope, I will learn. Regards |
Current timezone is GMT Sep 25, 2026, 11:19:14 PM |
