Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Half walls and bulkheads |
| Print at Sep 25, 2026, 11:21:42 AM | |
| Posted by VE6CPU at Jan 30, 2018, 5:43:07 PM |
Half walls and bulkheads Hello. I'm designing a room and I have a half wall that I can't figure out how to draw it. Is there a way to make a wall that is only a certain height not from floor to ceiling? Also is there a way to make it say drop down from the ceiling two feet? I need to make a bulkhead in my basement that holds all of the forced air trunks and some electrical and plumbing. Thanks. |
| Posted by GAthena at Mar 25, 2018, 11:17:57 PM |
Re: Half walls and bulkheads Create the wall with your desired height. Export the wall as .obj next import it to your furniture library. Once you click and drag the wall on to the floor plan,you can change the elevation. |
Current timezone is GMT Sep 25, 2026, 11:21:42 AM |
