Print at Sep 30, 2026, 9:41:02 AM
Posted by peterweaver at Feb 25, 2018, 5:25:46 PM
Import Furniture
Hi there,
I am trying to import a furniture.
After import a sizes are displayed differently than original sizes.
Even when I type in sweethome: width,depth,height etc-an object is still different.
Any ideas, what should I do?
Cheers
Posted by Puybaret at Feb 25, 2018, 8:36:59 PM
Re: Import Furniture
What do you mean by original size? In which format is your imported model?
Posted by peterweaver at Feb 25, 2018, 9:07:20 PM
The model has been imported in .obj format.
When I put it into Import Furniture and original size is 600mmx600mmx880mm, then Furniture Import Wizard depth width height are totally different.When I retype it, then model becomes different.
On the plan it shows a bigger rectangle and the model (inside of the rectangle) very small etc.
Posted by Puybaret at Feb 25, 2018, 9:25:41 PM
How did you obtain this OBJ file? Would it be possible that you share it?
Posted by peterweaver at Feb 26, 2018, 2:38:06 PM
Hi Emmanuel,
I have just sent you an email with an attachment of the .obj file.
Cheers
Posted by Puybaret at Feb 26, 2018, 2:48:13 PM
You included in your model a small additional part far away from the main object. Removing it should help you obtain a correct model.
You could have guessed it because the 3D model isn't centered when you import it in Sweet Home 3D furniture import wizard.
Posted by peterweaver at Feb 26, 2018, 4:22:09 PM
Thanks a lot for your help.
Posted by peterweaver at Feb 26, 2018, 7:06:09 PM
Hi Emmanuel,
Another thing, which I can not sort out in Sweethome.
The object's front door has got a different colour and after Import Furniture there is still a grey colour, but it should be coloured.What Am I doing wrong during importing furniture in Sweethome?
I have sent you an object via email.
Posted by Puybaret at Feb 27, 2018, 10:17:09 AM
Colours are exported in the separated MTL file. When you import an OBJ file, you should generally keep the MTL file in the same folder (or the same ZIP file).
Posted by peterweaver at Mar 6, 2018, 7:33:25 PM
Emmanuel,
I am trying to create a photo and sometimes it is starting dark/grey.
I am showing a floor/ceiling and 3 lights above the table.
What Am I doing wrong?
Cheers
Posted by peterweaver at Mar 6, 2018, 8:09:02 PM
I have just figured it out.
Cheers
Posted by CIANFRES at Apr 2, 2018, 8:35:40 PM
Hi, I've downloaded a model .obj but i can't import it in my sweet home 3d. I've a Mac, maybe is it a problem?
I've downloaded it from a web site and in every folder there is the object and other files.
How can I import correctly the object?
Thank you
Francesca from Italy
Posted by Puybaret at Apr 2, 2018, 11:23:16 PM
If you use the Mac App Store version, you should import 3D models in zip archives.
For more information, please read the FAQ How can I import 3D models in OBJ, DAE or 3DS format with the Mac App Store version of Sweet Home 3D?
Posted by Steveworld7 at Dec 21, 2021, 2:11:44 PM
Hi! I have a ZIP file with a list of files inside as: 3ds, dae, obj, mtl and texture folders)
Importing this ZIP, the pouf inside remains white. Any suggest?
Thanks
Posted by Puybaret at Dec 21, 2021, 5:29:05 PM
DAE and 3DS files contain colors, at the opposite of OBJ files which colors are described in their accompanying MTL file (and sometime not well described). I would extract the DAE file ans try to import it.
Posted by Steveworld7 at Dec 27, 2021, 12:31:44 PM
I tried to import the .dae file only (after zipping it) but the pouf remains white ...
Inside this zip file there are 3 folders called: LODs, render, textures ... should I have to import these folders somehow?
Posted by Jo_Alfemo at Dec 27, 2021, 5:18:40 PM
Hi
If I want to make a texture what is the ideal size?
Tks
Posted by dape at Mar 18, 2022, 11:05:39 AM
Hi Peter, do not know if this can help, but if you are looking for more free 3D furniture models (and many more download formats), try here with 3DfindIT.com (have to register and then you can download for free whatever you need). Hope it helps, take care!
https://www.3dfindit.com/textsearch?lang=en_US&q=furniture
