Print at Sep 27, 2026, 10:15:06 AM
Posted by morellik at Feb 25, 2018, 7:27:18 PM
create sh3f library
I have a lot of objects to load in Sweet Home and I don't want to do it "one by one". Is there a program I can use to create a library sh3f ? Thank you.
Posted by Puybaret at Feb 25, 2018, 8:05:06 PM
Re: create sh3f library
Try the Furniture Library Editor.
Posted by morellik at Feb 28, 2018, 5:29:33 PM
All OK, thank you.
Posted by Lesni at Oct 21, 2018, 9:01:53 PM
To use this Editor, must I install Java?
My employer has restrictions on unauthorized programs.
Is there a way to have this as a plugin rather than stand-alone.
Posted by Puybaret at Oct 21, 2018, 10:06:33 PM
You must have Java somewhere, installed with an installer or copied from elsewhere.
The Furniture Library Editor doesn't exist as a plug-in.
Posted by Lesni at Oct 22, 2018, 2:17:35 AM
Thanks,
I found the javaw in the bin folder.
Using the command I can start it.
Posted by Lesni at Oct 22, 2018, 2:31:18 AM
In Sweet Home 3D I put an ini file to make the rows and columns readable. Is there one for this program also?
Posted by Puybaret at Oct 22, 2018, 8:31:25 AM
If you have a HiDPI screen, install Java 10 or 11. That will fix the issue.
Note that the ini file used for this purpose with Sweet Home 3D isn’t necessary with version 6.0, and I’ll be happy to know how it works for you.
Posted by dorin at Oct 22, 2018, 6:01:46 PM
If You've already import the furniture piece-by-piece (name are shown in italic), You could save all in a personal furniture library which could be loaded when needed.
1. Install the ExportToSH3F-1.0.sh3p plugin;
2. In menu: Furniture > Export imported furniture to SH3F...
Note: Sometime You need to make fine adjustment in PluginFurnitureCatalog.properties file.
