Print at Sep 28, 2026, 11:33:06 AM
Posted by morellik at Feb 28, 2018, 5:27:46 PM
tiled texture
I'd like to add a painting to a wall using as texture a jpeg picture of monalisa.
I can import the texture but I get a tiled result. Is there a workaround or I must
create a 3d object outside SH ? Thanks.
Posted by VeroniQ at Feb 28, 2018, 6:15:10 PM
Re: tiled texture
You can use this frame , for example, and change the canvas texture with imported Mona Lisa which will apply without tiled aspect. Only mind the proportion.
Posted by VeroniQ at Apr 23, 2018, 1:39:20 PM
Re: tiled texture
On the Sweet Home 3D Youtube channel, you will find a tuto to Customize a frame.
