Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to set up sunshine thru window and shadow inside of a building? |
| Print at Oct 13, 2026, 7:05:53 PM | |
| Posted by peterweaver at Mar 8, 2018, 6:33:23 PM |
How to set up sunshine thru window and shadow inside of a building? Hi there, Is it any possibility to set up a sunshine angle and direction through window into a building etc? Cheers |
| Posted by okh at Mar 8, 2018, 8:17:25 PM |
Re: How to set up sunshine thru window and shadow inside of a building? ..sunshine angle and direction through window into a building... The rendering relies on the settings in the compass to provide correct sunlight direction. If you set orientation, lat/long and time/date you can get all possible sunlight angles. Look for enkonyito's and Ceciliabr's forum posts on Photo-video rendering if you need to adjust further light parameters. But yes, you can get pretty much any illumination you wish. okk |
Current timezone is GMT Oct 13, 2026, 7:05:53 PM |
