Print at Aug 30, 2026, 11:27:11 AM
Posted by bdfd at Mar 18, 2018, 10:03:08 AM
confused   Click on upper wall, impossible !
I don't know if it's a bug but I've had this many times. sad
When there are 2 walls superimposed, one on the lower level and the other on the upper level.
When I want to modify the upper wall, he always selects me the lower wall.
I am in the desired tab. biggrin
Why ?
I have to make invisible the lower level to have access...
Is this really a bug ?
confused
Posted by Puybaret at Mar 18, 2018, 9:07:37 PM
Re: Click on upper wall, impossible !
A wall can be selected in a upper level if it’s higher than the height of the level it belongs to. So, make walls of the lower level smaller, or choose your wall with the Select object menu available in the contextual menu of the plan where you right click.
