Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Custom roof. Tutorials do not help. |
| Print at Sep 25, 2026, 3:44:12 PM | |
| Posted by rulllesss at Mar 20, 2018, 7:57:59 PM |
Custom roof. Tutorials do not help. Hello, I'm new to Sweet Home 3D, but find it quite useful. I have been trying to build a roof. I went through some videos and samples how to build custom roof from walls (then export to obj and import as furniture) The problem is that one part of the roof can be be build from either rectangular triangle (slooping wall) or rectangle (simple wall). What I need is parallelogram. Pleae look at the image here is where I stucked Could you suggest how can I get parallelogram (which can not be done as 2 rectangular triangles) ? |
| Posted by Puybaret at Mar 21, 2018, 8:48:50 AM |
Re: Custom roof. Tutorials do not help. Hello, Maybe you could try the Shape Generator plug-in available here. You can also create a dummy room at an upper floor, export it at OBJ format and import the generated file, or use a box + 2 triangles. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rulllesss at Mar 25, 2018, 9:58:38 AM |
Re: Custom roof. Tutorials do not help. Thanks a lot. That helped! |
Current timezone is GMT Sep 25, 2026, 3:44:12 PM |
