Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Looking for a Workshop Features |
| Print at Sep 26, 2026, 5:44:24 PM | |
| Posted by BillyZed at Mar 22, 2018, 4:40:09 AM |
Looking for a Workshop Features Good morning, I've looked around here, without success, to see if there are any features to design a workshop which will have I-beams or similar steel beams and be able 25' high. This will be used for a car workshop and some steel and work work. Is there anything like that? Or would I just do a tall first floor with the current software? This is my first post here and I'm really enjoying the SW3D program. The community seems pretty friendly here, too. Best regards, Billy |
| Posted by Puybaret at Mar 22, 2018, 5:51:51 PM |
Re: Looking for a Workshop Features Hello Billy, You could build I beams by assembling thin boxes. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BETHAROO at Oct 3, 2018, 2:47:02 AM |
Re:
Looking for a Workshop Features Did you figure it out? We are wanting to do a plan for a shop. |
| Posted by VeroniQ at Oct 3, 2018, 2:34:32 PM |
Re: Looking for a Workshop Features Example 12 of the Gallery might help you?... |
| Posted by Mike53 at Oct 3, 2018, 9:13:29 PM |
Re: Looking for a Workshop Features Hi Beth , Hi Billy, sorry i missed your 1st comment. As Puybaret has already said, you can use the box from the library to create an I beam, 2 for the horizontals and 1 for the vertical, this option however may have limits,the ends would all be 90 degrees to the length and if if you exported it as in obj. making it taller would affect the thickness of the horizontals and making it wider would affect the thickness of the vertical, this would also affect end caps , cleats etc fitted prior to resizing, you can avoid some of this by using the shape generator plug-in to create the 3 components therefore having angled ends to represent, for instance, the pitch of a roof. You could also, if you wished, create and an RSJ or other profiles with the "create room" feature, i find multiplying each measurement by 4 easier to create, then turn 90 degrees during import and resizing. Mike PS when using the create room feature, do so on a raised level or the component will have no depth. |
Current timezone is GMT Sep 26, 2026, 5:44:24 PM |
