Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Floor Textures with gaps from lower level walls |
| Print at Oct 13, 2026, 1:05:25 AM | |
| Posted by k1r2t3n at Apr 25, 2018, 9:50:55 AM |
Floor Textures with gaps from lower level walls Hi there, I would appreciate your help: I am currently building our new home in sweet home and started to apply textures. unfortunately the textures seem to show gaps where the lower level walls are. see screenshot. What is wrong? https://www.dropbox.com/s/d59csregk2kk5id/gapsintextures.png?dl=0 thank you. Kirsten |
| Posted by dorin at Apr 25, 2018, 6:50:23 PM |
Re: Floor Textures with gaps from lower level walls What is wrong? The height of walls in level UG are at least as the elevation of the level EG. Solution: Verify the height of walls on level UG and reduce them. or Increase the elevation of level EG. PS Don't forget: every level have a floor thickness; You must take it in consideration. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by k1r2t3n at Apr 25, 2018, 7:12:56 PM |
Re: Floor Textures with gaps from lower level walls Dear Dorin, thank you! I added another 1cm to the elevation. This did the trick! Perfect! Cheers, Kirstne |
Current timezone is GMT Oct 13, 2026, 1:05:25 AM |
