Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Measure-tool - snap? |
| Print at Sep 25, 2026, 2:32:15 PM | |
| Posted by MrGlad8 at Apr 29, 2018, 7:35:04 AM |
Measure-tool - snap? How do I snap the measure-tool to for example a corner? I dont want to relie on my shaky hand :) Tried holding down like ctrl or something but doesnt seem to work! |
| Posted by Puybaret at Apr 29, 2018, 7:47:33 AM |
Re: Measure-tool - snap? With the Dimension lines tool, double clicking on the side of a room, a wall or an object will create a dimension line measuring that side. Isn’t it more handy? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MrGlad8 at Apr 29, 2018, 8:03:39 AM |
Re: Measure-tool - snap? With the Dimension lines tool, double clicking on the side of a room, a wall or an object will create a dimension line measuring that side. Isn’t it more handy? Absolutely! It works nice on objects for example a window, or a whole wall in a room. But if I want the measure from the corner to where the window start, it doesnt works just by double licking because then it still takes the whole wall even if its a window in the way. Or am I doing something wrong? |
| Posted by Puybaret at Apr 29, 2018, 1:54:46 PM |
Re: Measure-tool - snap? When the mous pointer is on the corner, there are some vertical and/or horizontal guide lines that should help you to click at the right point. Hope you can use them. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cadilhac at Jan 2, 2023, 12:13:47 AM |
Re: Measure-tool - snap? Apologies for replying to a thread from the past decade; I have the same question as OP, and the same lack of trust for my pixel-perfect clicking abilities. I wish to measure the distance between two parallel walls: - How can I make sure that the *first* click is precisely on the side of the wall? - Even harder, as there are no guides in that case, how can I make sure this is also the case for the *second* click? Thanks! |
Current timezone is GMT Sep 25, 2026, 2:32:15 PM |
