Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Remastered furniture |
| Print at Oct 12, 2026, 1:23:56 PM | |
| Posted by dorin at May 3, 2018, 1:04:18 PM |
Remastered furniture 1. On official Furniture and in Contributions properties files I've add: doorOrWindowWallThickness#nn=xx.x doorOrWindowWidthDepthDeformable#nn=false for all doors and windows which have specify the doorOrWindowCutOutShape#nn=xxxx parameters for some of them I need to add also the doorOrWindowWallDistance#nn=xx.x I verify all to look correctly on 7.6 and 50 cm wall thiknes. 2. On Furniture.jar: - add new category: Decorations; Geometry; Light sources; Roof - rename category "Staircase" to "Staircases & railing" - verify all obj file and add mtl files in contributors 3. On Contributions.sh3f: - verify all obj file and add mtl files where neded; some of them I regenerated by SH3D - create separate folders for all furniture (170 from 469); modify properties accordingly - prevent from loading some furniture (ignored#nn=true): -- which are already in official Furniture (25) -- those which are identical as object but only with different colors (9) Note 1: who whant to restore some of them is souficient to comment the "ignored" line. Note 2: to prevent overwriting the original I save this with Contributions-M.zip ("M" from modify) Note 3: I don't modify the translation in specific files; Who want to test them could be downloaded from here: Furniture ; Contribution-M If something went wrong or suggestions please indicate the furniture name and id number. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 12, 2026, 1:23:56 PM |
