Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Stairs |
| Print at Sep 30, 2026, 7:21:44 PM | |
| Posted by kjeldc at May 8, 2018, 4:53:17 PM |
Stairs I miss a straight staircase with just 8 steps and about 1.25 m. in height as they are found in many properties with apartments. It may have glass rails ![]() |
| Posted by okh at Jun 6, 2018, 3:10:53 PM |
Re: Stairs No glass rails, but I did have a half-height staircase to use with a separate landing/level. You can remove the railings and ballusters on each side individually by editing the different element textures/colours. See SF 3d-models 382. stairs_mini.sh3d (.sh3d file with cutout). stairs_mini.zip (just model .obj - will not cut accurately as the railing extends beyond the top of the stairs). ok ![]() |
| Posted by Worldtraveller at May 1, 2020, 7:58:06 PM |
Re: Stairs Is it possible to make stairs a parametric item? (select the number of stairs, and/or a default size) like doors and windows? |
| Posted by SeppoV12 at May 3, 2020, 1:38:53 PM |
Re: Stairs Dorin's plugin Multiple Paste & Distribute might fill part of your expectations. Check this thread. Seppo |
Current timezone is GMT Sep 30, 2026, 7:21:44 PM |
