Print at Sep 24, 2026, 10:08:13 AM
Posted by corradoventu at May 20, 2018, 8:12:24 PM
Furniture library editor 2.22 not working?
On my Ubuntu 18.10 Cosmic I have Furniture library editor 1.22
On my Ubuntu 17.10 Artful I have Furniture library editor 1.21
on both I downloaded and unpacked 2 libraries:
3DModels-BlendSwap-CC-0-1.6.3.zip and 3DModels-LucaPresidente-1.6.3.zip
using library editor 1.21 I can see the content while with library editor 1.22 I click on 'open library' then I select the library but nothing happens. Should I report a bug? what documentation should I attach?
thanks
Note: On Ubuntu 18.10 Sweet Home 3D works fine so I think java environment is correct.
Posted by dorin at May 20, 2018, 8:30:45 PM
Re: Furniture library editor 2.22 not working?
NO, java is not correct!
I try to reproduce Your issue:
-with installed java (10 or 9) from system =>nothing happens
-with jre8 from SH3D all work as expected.
So, blame the Ubuntu's java, like I do with my debian's java devilish
Posted by corradoventu at May 21, 2018, 6:37:09 AM
I have no idea how to open a bug on java, will you open it?
Note: I have same problem also in Ubuntu 18.04 LTS
Posted by dorin at May 22, 2018, 9:06:39 AM
Me too. But, Puybaret try few years ago to do this and the answer was something like "we don't care".
The java applications are write with and for a specific version; some instruction being deprecated or replaced in newer version of java.
If so, open an SH3D sesion, verify the java version You use (Help->About).
If is 9 or 10 try to import some furniture library and see if appear in catalog. In my tests they don't which mean don't work fine.
If You are interested I could explain You my way to make it usable (SH3D, editors and even AOI which work bather with jre6;7 or 8)
Posted by corradoventu at May 25, 2018, 11:05:01 AM
I noted: On Ubuntu 18.10 Sweet Home 3D works fine but this is FALSE:
it works fine to edit a project, but import library does not work.
See my bug https://sourceforge.net/p/sweethome3d/bugs/832/
so the problem seems similar in Sweet Home 3D and Furniture library editor
Posted by otadmin at Apr 15, 2020, 12:37:24 PM
On Linux Mint 19.3 Java 11 is installed. Downgraded it to Java 8 as suggested but library editor is still not showing the content of the library it opened. However, it asks if I want to save the file when closing the editor.
