Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: save a home |
| Print at Sep 26, 2026, 11:12:01 PM | |
| Posted by joaovaz at May 29, 2018, 8:02:35 PM |
save a home When I trie to save a home draw, the message apears: Cant't save home in "C:\Users\Me\Desktop\aaa.sh3d" RecorderException: Can't save file C:\Users\Me\Desktop\aaa.sh3d" java.io.FileNotFoundException: C:\Users\Me\Desktop\aaa.sh3d" (The system can not find the file specified) I work with a Windows 10 PC Thanks for your help Joao |
| Posted by Puybaret at May 29, 2018, 11:52:56 PM |
Re: save a home Are you sure you have the rights to write in the folder C:\Users\Me\Desktop? Or did you try to save your home under a different name? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by joaovaz at May 30, 2018, 1:15:01 PM |
Re: save a home The problem continue. I am the owner and administrator off the PC and have full control. I have JavaSetup8u171 installed. Thanks Joao |
| Posted by Puybaret at May 30, 2018, 1:43:02 PM |
Re: save a home Did you try to save an empty file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by joaovaz at May 30, 2018, 8:25:03 PM |
Re: save a home I opened the Sweet Home program and without doing anything tried to save it. The message was the same. Thanks, Joao |
| Posted by Puybaret at May 30, 2018, 8:40:42 PM |
Re: save a home Please try to save in another folder or a USB key. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by joaovaz at May 31, 2018, 11:04:58 AM |
Re: save a home When I saved it to a USB drive, it already worked. I do not understand why. Anyway I can work. I moved the file created in Sweet Home from the USB drive to the Desktop and it also worked. Thank you for your help. John |
| Posted by Glommer67 at Feb 17, 2021, 7:39:24 PM |
Re: save a home I'm having the same problem, but slightly different circumstances. It's been working today, but has suddenly come up with this error when trying to save. I've just rearranged things, not added anything (except a cube and dimensions). It's my own home pc that I have gobal permissions on, I've tried different folders and a USB. Can't think what else to do. Help! Gary |
| Posted by Puybaret at Feb 18, 2021, 9:01:27 AM |
Re: save a home Maybe you encountered an issue reported by some users about some security settings in Windows which forbid to save some files from an application if not allowed. Please check if it's your case. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 11:12:01 PM |
