Print at Aug 25, 2026, 10:07:39 AM
Posts: 11   Pages: 2   [ Previous Page | 1 2 ]
Posted by treehousenorris2 at Nov 21, 2024, 6:32:37 PM
Re: SH3D on Windows 10 on ARM works using DirectX
I have a Surface Pro with Windows 11 Home that already has DirectX 12, using my fork of 7.4 with a 32 bit install. The 3D rendering pane contents looked correct, but sometimes the dialog boxes (to edit a wall's settings for example) would have areas of grayed pixels or the whole dialog was black. And eventually would show a popup that "must exit now because of a fatal error in 3D rendering system. Do you want to save all modified homes?".
I tested the last solution by arm64appcompatguy with the reinstall and saw that it applied because the metal-colored menus were present. However, I could still trigger the fatal error message by opening a(nother) new (empty) home. A confirm box just before that said "Neither the Hardware and Software renderers..."
