Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: add furniture to home |
| Print at Oct 19, 2026, 4:04:09 AM | |
| Posted by trandel at Jun 19, 2018, 11:16:09 AM |
add furniture to home Hi Having a problem adding furniture. I drag and drop an armchair but the result is a tiny image. When I try to edit its size the result is still very small and the pic is of a cabinet? I am using centimetres and all seemed OK with the walls etc but the furniture seems about 10 times too small i.e. 90cm I change to 900cm to see it. Am new to Sweet Home and assume I must be doing something wrong?? Regards Tony Randell |
| Posted by Puybaret at Jun 19, 2018, 2:47:41 PM |
Re: add furniture to home Hi Tony, You could have imported a 3D model with small dimensions. If this is the case, did you check then fix the size proposed at the 3rd step of the furniture import wizard? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 19, 2026, 4:04:09 AM |
