Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Install pugin in Linux version |
| Print at Oct 12, 2026, 3:59:19 PM | |
| Posted by ZAJDAN at Jun 23, 2018, 11:24:04 AM |
Install pugin in Linux version Hello, I downloaded SweetHome3D Linux version, where it runs without installation (just unpack and launch SweetHome3D script) The application it self runs without problem. As next step I wanted to add some the Plugin. Here http://www.sweethome3d.com/pluginDeveloperGuide.jsp I have read, that plugins should be added here: .eteks/sweethome3d/plugins of your user folder. In my case the subfolder plugins was not there, so I created it As next step I downloaded this plugin: https://sourceforge.net/p/sweethome3d/plug-in...omputeRemainderVolume.rar and placed to the recommended folder: .eteks/sweethome3d/plugins of your user folder. I started the application, but in menu I do not see some new section ..like the Tool. What I do wrongly? Thanks for any hint! ZAJDAN |
| Posted by Puybaret at Jun 23, 2018, 4:02:52 PM |
Re: Install pugin in Linux version I guess you are trying to install the plug-in #8. You should copy TheRestOfTheFurnitureInTheRoomplugin.jar file in .eteks/sweethome3d/plugins folder rather than the RAR file which contains the source code of the plug-in. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ZAJDAN at Jun 24, 2018, 2:22:43 PM |
Re: Install pugin in Linux version Of course, This is logic, that we have to unpack and place there the content of the package. Exactly this I made. But in the case of the plugin which I wanted to it is RAR. https://sourceforge.net/p/sweethome3d/plug-in...omputeRemainderVolume.rar 1) I downloaded the package 2) Unpacked 3) The content I placed into the mentioned directory look here: ls /home/zoja/.eteks/sweethome3d/plugins/ |
| Posted by Puybaret at Jun 24, 2018, 11:26:15 PM |
Re: Install pugin in Linux version Maybe my message wasn't clear enough: Do not copy RemainderPlugin.java it won't work. Copy TheRestOfTheFurnitureInTheRoomplugin.jar in /home/zoja/.eteks/sweethome3d/plugins/ ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ZAJDAN at Jul 2, 2018, 9:59:20 AM |
Re: Install pugin in Linux version Thank You... TheRestOfTheFurnitureInTheRoomplugin.jar works. But the plugin about which I spoke I thought will be able count cubic meters of walls. Exist some such pluging to get m³ of wall? |
| Posted by leo321 at Jul 18, 2018, 1:38:28 AM |
Re: Install pugin in Linux version Thanks for this |
Current timezone is GMT Oct 12, 2026, 3:59:19 PM |
