Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.0 |
| Print at Oct 2, 2026, 9:02:57 AM |
| Posted by hansmex at Oct 5, 2018, 12:01:34 PM |
Re: Sweet Home 3D 6.0 I just copied the new files in the beta-11 directory, thinking that was all I needed to do. I forgot that I needed the Xmx-thing to change memory usage. Rest assured, I didn't hit myself overly hard. :-) ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ceciliabr at Oct 5, 2018, 3:34:33 PM |
Re: Sweet Home 3D 6.0 I have been doing some extensive testing of v6 β14 using OSX Mojave, and have found a couple of things I would like to mention: 1) β14 does not read textures correct for files created with older versions: ![]() 2) When importing furniture, the status of the Continue-button changes before the model has loaded. ![]() 3) When cancelling a rendering by mistake, the rendering just stops without offering a chance to reconsider your choice. It's very easy to cancel a render process unintentionally and loose hours of rendering, so this is important! Part from this: All thumbs up! Cec |
| Posted by hansmex at Oct 5, 2018, 3:51:04 PM |
Re: Sweet Home 3D 6.0 3) Rendering stopping without asking can happen also under other OS's, especially in the beginning of the rendering process. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Oct 5, 2018, 7:03:50 PM |
Re: Sweet Home 3D 6.0 Cecilia, thanks for your report. 1) Could you send me a demo file with textures that don't behave as in version 5.7? 2) I don't think it's very serious, moreover in the 3rd step of the furniture import wizard. 3) The stop button starts to warn you once the rendering has already lasted 30s. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ceciliabr at Oct 5, 2018, 8:30:08 PM |
Re: Sweet Home 3D 6.0 Could you send me a demo file with textures that don't behave as in version 5.7? I have unfortunately already re-textured all the walls and saved the project with v6. 2) I don't think it's very serious, moreover in the 3rd step of the furniture import wizard. This IS serious:![]() This happens if you press Continue too early. 3) The stop button starts to warn you once the rendering has already lasted 30s. I noticed. But the warning pop-up is hidden behind the render window. Cec |
| Posted by bdfd at Oct 6, 2018, 6:29:43 AM |
Re: Sweet Home 3D 6.0Hi, At this day, none problem with v6 beta14 ! 1. Furniture import wizard : OK 2. Renderings with standard Q4 : OK. with PVR 1.5 Q4 : OK (0 to 100%). => estimated time given at 1% : 08h23mn. => estimated time given at 2% : 07h01mn. => estimated time given at 3% : 08h13mn ??? . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Oct 6, 2018, 10:04:03 AM |
Re: Sweet Home 3D 6.0 3) The stop button starts to warn you once the rendering has already lasted 30s. That's what I noticed, so no problem for me.But... I did notice some strange behavior. When I make a quick render using Q1, I get a different picture from what I expect. (See screenshot). However, when I make the same render in Q3 everything is normal. ![]() ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ceciliabr at Oct 7, 2018, 12:13:44 AM |
Re: Sweet Home 3D 6.0 @ Puybaret Can you check copy/paste from other projects? I'm unable to copy /paste anything from this project with beta 14. In v5.7 it works fine. Cec |
| Posted by Puybaret at Oct 7, 2018, 5:43:03 PM |
Re: Sweet Home 3D 6.0 Cec, I couldn't reproduce the 3D error during furniture wizard. I already saw it happen rarely, but I could force the error myself during the past days. I even tried to press <enter> to continue very quickly between each step, but even this behavior didn't cause problems. Does it happen each time in your case? I also successfully tested the copy/paste between projects. I suspect you tried to copy something from Sweet Home 3D 5.7 then paste it in a new project running with Sweet Home 3D 6.0 Beta, in which case it can't work. Copy/Paste works only within the same Sweet Home 3D program. Hans, I couldn't reproduce your issue too. There must be an additional parameter... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ceciliabr at Oct 8, 2018, 11:01:50 AM |
Re: Sweet Home 3D 6.0 Does it happen each time in your case? More or less each time. I can reproduce this error every time I'm importing bigger models. Not so often with smaller. It would be nice if continue didn't work until it was safe to use. Copy/Paste works only within the same Sweet Home 3D program. Of course. I even saved the linked project with v6 and re-opened it. After copying a spotlight, the only option I get is to Paste Style – Paste is greyed out on the menu. Cec |
Current timezone is GMT Oct 2, 2026, 9:02:57 AM |
