Print at Sep 27, 2026, 9:13:22 AM
Posted by enkonyito at Jul 3, 2018, 3:42:49 AM
Interaction between Java Web Start version and installer version
When I launch Sweet Home 3D with Java Web Start, I cancel the message
"An association already exists with the extension .sh3d.
Do you want to replace it?
The association is currently used by C:\Program Files\Sweet Home 3D\SweetHome3D.exe"
After closing the Java Web Start version, if I double-click on the Sweet Home 3D desktop icon I have this error message
"Impossible to launch the application.
Name: Sweet Home 3D
Publisher:
In the Start menu, the eTeks Sweet Home 3D folder contains 2 files named Sweet Home 3D.
The first launches the installer version and the second displays the above error message.
To reuse the desktop shortcut normally I need to reinstall SweetHome3D-5.7-windows.exe.
After that, impossible to laucnh the beta version 6.0 even if the name of the desktop icon or file in the Start menu is different (Sweet Home 3D 6.0 Beta).
I get the same error message as before with the name of the beta version.
EnkoNyito
Posted by Puybaret at Jul 6, 2018, 11:11:48 AM
Re: Interaction between Java Web Start version and installer version
I removed the offline tag and the extension associations in the JNLP file for the Beta 2.
Hope this will help...
Posted by enkonyito at Jul 6, 2018, 5:12:40 PM
Perfect, good job!
EnkoNyito
