Print at Oct 16, 2026, 10:39:40 PM
Posted by esse2003 at Jul 14, 2018, 6:39:29 PM
Wall capy and paste
Hi all. Is possible to make a copy and paste of walls already built in another project? I need them with a certain angle, that’s the problem. Is that possible? I don’t want to import as an obj because then i cannot edit anymore. Thanks again!
Posted by Puybaret at Jul 14, 2018, 7:33:27 PM
Re: Wall capy and paste
You can select the walls you want to copy, choose Edit > Copy menu item, open the other project, click in its plan and choose Edit > Paste menu item.
Posted by esse2003 at Jul 14, 2018, 10:10:34 PM
Yes, that’s correct but then i cannot give to the walls an angle? Right?
Posted by Puybaret at Jul 15, 2018, 11:54:22 AM
Maybe you could try AdvancedEditing plugin?
Posted by esse2003 at Jul 15, 2018, 1:50:06 PM
I tried but you cannot do nothing with walls. There is not a function ti rotate walls unfortunately. Thanks anyway..
Posted by Puybaret at Jul 16, 2018, 9:30:36 AM
I just tried and you can rotate walls with the plugin. Please try again.
