Print at Sep 26, 2026, 5:44:29 PM
Posted by enkonyito at Jul 16, 2018, 10:47:18 PM
Modify the materials of a piece of furniture
In the HomeMaterial class , only methods for obtaining information about the color, name, shininess, or texture of a material are defined.
Is it possible to change the value of these parameters other than by manually accessing the Home.xml file?
When there is more than a hundred pieces of furniture, it's tiring.
EnkoNyito
Posted by Puybaret at Jul 16, 2018, 11:35:12 PM
Re: Modify the materials of a piece of furniture
HomeMaterial objects are immutable like a few other ones in Sweet Home 3D like BackgroundImagel, Sash, TextStyle... instances. But I guess your question isn't about the advantages of immutability, right?
As you're a programmer, you could call the setModelMaterials in HomePieceOfFurniture class with a new array of HomeMaterial instances. What is the problem to do that?
Posted by enkonyito at Jul 18, 2018, 1:58:02 AM
HomeMaterial objects are immutable like a few other ones in Sweet Home 3D like BackgroundImagel, Sash, TextStylel... instances. But I guess your question isn't about the advantages of immutability, right?
No, I didn't know the advantages of immutability .
Sometimes we miss out on the most obvious things.
I had not yet figured out how to use this method in my plugin.
Thanks
EnkoNyito
Posted by enkonyito at Jan 8, 2019, 11:40:32 PM
Is it normal that sometimes the getModelMaterials() method only returns one material when there are several?
EnkoNyito
Posted by enkonyito at Jan 24, 2019, 9:13:44 PM
It's normal and I was able to adapt it to my plug-in. smile
EnkoNyito
