Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Roofs |
| Print at Sep 24, 2026, 1:09:13 PM | |
| Posted by AdeleAlli at Jul 23, 2018, 6:18:06 PM |
Roofs In my opinion, a nice feature that Sweethome3D could provide is the possibility of creating a roof. An option similar to creating a floor or wall but that creates a roof based on the size you choose, as usual. In this way the current creation of the roof, which requires particular time, would be simpler, like everything that can currently be done with SH3D. Thank you for the great work! |
| Posted by AdeleAlli at Aug 11, 2018, 2:48:37 PM |
Re: Roofs Can someone say me if it is so difficult to implement this feature into sh3d? I would like to try to realize it someway. :) |
| Posted by VeroniQ at Aug 11, 2018, 5:52:14 PM |
Re: Roofs You already did well in your little house! But if you want to see more roofs, have a look in this blog article : Okh especially did a nice library? |
| Posted by okh at Aug 11, 2018, 6:54:07 PM |
Re: Roofs ..difficult to implement this feature into sh3d? I agree it would be nice to get a roof automatically. At least if it were exactly the kind of roof I wanted. I would not know about the programming bit, but I have come across house planning programs where the roofs would not work properly for anything but very simple projects. And even then, the overhang and the joints became strange. So, at the end of the day, I kind of prefer SH3D where you can fit a model roof...Actually, just like you made nice roofs on your Mini Cottage already. ![]() |
| Posted by AdeleAlli at Aug 14, 2018, 10:26:05 AM |
Re: Roofs You already did well in your little house! But if you want to see more roofs, have a look in this blog article : Okh especially did a nice library? Hi, thank you very much for the link about the roofs!!! |
| Posted by AdeleAlli at Aug 14, 2018, 10:27:57 AM |
Re: Roofs Thank you okh, I think you are right, using roof objects is better to create different kind of roofs. Thank you for the library about roofs :). |
| Posted by AdeleAlli at Aug 14, 2018, 1:16:53 PM |
Re: Roofs Okh I want to ask you how did you realize this roof on the right of the picture, I need to do exactly this kind of roof. ![]() |
| Posted by UbuntuBirdy at Aug 14, 2018, 1:44:53 PM |
Re: Roofs 5 minutes CAD: pyramid roof ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by okh at Aug 15, 2018, 10:02:52 AM |
Re: Roofs As UbuntyBirdy says, and as with most roofs, the model is quite simple to make with AoI, Blender, Sketchup or FreeCad. If you know how. The one in the image, is made from identical roof module triangles), fit together and grouped. While that is a flexible and generic approach to enable many kinds of roofs with few models, it is a bit cumbersome. So, I think there are also some pyramid models posted in SourceForge (roofs). For a pyramid roof, I would probably do like UbuntyBirdy, but for my own use I would probably also add a ceiling, sides and texturemap the roof (vt) so a texture (rooftiles) you add later will look the same on all sides, e.g. an .obj file looking something like this. Copy the text and save as pyramidroof.obj and import to SH3D (.mtl not needed for std colours: Java3DCubeColorsWithTransparency). # pyramid roof with ceiling and texture co-ords |
| Posted by Puybaret at Sep 6, 2018, 11:48:27 AM |
Re: Roofs Maybe see if you could help youseeus on the roof plug-in he started to program. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 1:09:13 PM |
