Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Bump mapping |
| Print at Oct 17, 2026, 9:51:13 AM | |
| Posted by Ceciliabr at Jul 25, 2018, 1:13:08 AM |
Bump mapping I have been doing some experiments with texturing (when my surroundings have allowed it), and I have found that Sunflow can do a lot with texturing that I was not aware of. Among the features listed for Sunflow we can find Bump/normal mapping via surface modifiers. I have studied the Wavefront mtl-bible and tried my best to get this to work, but I must admit that my skills are not nearly what I imagined. So I give up and ask for help: Does anyone know how to implement bump/normal-mapping for Sunflow? It really makes a difference. ![]() The obj file and the bump map can be downloaded here Cec |
| Posted by enkonyito at Dec 12, 2018, 3:21:37 AM |
Re: Bump mapping Hi Ceciliabr, Sunflow standalone allows the use of bump/normal mapping via modifiers. (example bump_demo.sc) The .obj format also allows the use of bump mapping by adding the 'map_bump' or 'bump' keyword followed by the texture path in the .mtl file. Unfortunately, Sweet Home 3D only takes into account the 'map_Kd' keyword in the export/import OBJ. Enko ---------------------------------------- EnkoNyito |
| Posted by nemetonia at Dec 12, 2018, 6:42:05 AM |
Re: Bump mapping Hello, I think that this was used by bdfd for Mars since january 2017 ??? See here : ![]() |
| Posted by Puybaret at Dec 12, 2018, 5:48:20 PM |
Re: Bump mapping nemetonia, as Sweet Home 3D doesn't support bump mapping, this can't be the case and must be a visual effect. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by nemetonia at Dec 13, 2018, 6:45:32 AM |
Re: Bump mappingnemetonia, as Sweet Home 3D doesn't support bump mapping, this can't be the case and must be a visual effect. So I said 'used by' and not 'created with'... ![]() |
| Posted by Ceciliabr at Dec 13, 2018, 6:51:43 AM |
Re: Bump mapping Any chance it might be included in a future version? |
Current timezone is GMT Oct 17, 2026, 9:51:13 AM |
