Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: rotating a whole house |
| Print at Oct 19, 2026, 8:16:38 AM | |
| Posted by denmyos at Aug 3, 2018, 6:57:35 PM |
rotating a whole house After many hours of work i just realize that my house and garden walls are facing the wrong way. I need to rotate 4 levels 90 degrees. But i dont see any options to rotate whole levels or object made of several pieces. Am i missing something here.? ![]() |
| Posted by UbuntuBirdy at Aug 3, 2018, 7:23:04 PM |
Re: rotating a whole house "Edit" => "select all at all levels" "Edit" => "rotate" But, you can just rotate the compass if this is the problem. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by denmyos at Aug 3, 2018, 7:26:13 PM |
Re: rotating a whole house I realize that Rotate only comes with advanced editing plugin. http://www.sweethome3d.com/plugins.jsp Which i installed. Works nicely. Thank you :) |
| Posted by UbuntuBirdy at Aug 3, 2018, 7:52:05 PM |
Re: rotating a whole house I realize that Rotate only comes with advanced editing plugin. http://www.sweethome3d.com/plugins.jsp Which i installed. Works nicely. Thank you :) WOW, sorry, I did not realize that! Thanks for correction! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Oct 19, 2026, 8:16:38 AM |
