Print at Sep 23, 2026, 2:32:52 PM
Posted by Mike53 at Sep 4, 2018, 2:16:33 PM
New Build.
Here are some images of a new project. The inside is not done yet so this is the outside and some detailing.
Footings
Damp Coarse
Ground floor
Timber framing
Ceilings
fascias and soffets
Roofs
Finally the front, following Cec's excellent tutorial
I have made a few tweaks since some of these were made, they will show later.
Feel free to comment, advice is always welcome.
Posted by AdeleAlli at Sep 4, 2018, 8:42:54 PM
Re: New Build.
Hi Mike53,
I simply love and appreciate very much the images that show how the house is growing starting from the basement! Good work and hope to see the interiors soon!
Best Regards,
AdeleAlli
Posted by Ceciliabr at Sep 5, 2018, 11:04:32 AM
Re: New Build.
I love seeing how the detailed construction is being erected (and ! love the front-shot) smile
This is solid work, Mike!
Posted by Mike53 at Sep 8, 2018, 12:22:52 PM
Re: New Build.
Thank you Cec
Thank you Adele, your build got me thinking about it.
As for interior :- here are 2 of the bathroom.
I removed the shower screen for this render.
and 1 had to remove a wall to get this shot
Posted by VeroniQ at Sep 8, 2018, 12:39:21 PM
Re: New Build.
Yes, very interesting way of "building" and great result. How many bedrooms, at the end?
Posted by Mike53 at Sep 8, 2018, 3:34:48 PM
Re: New Build.
Hi VeroniQ
Thank you for the comment.
here are the floor plans.
Ground Floor
1st floor
Posted by Mike53 at Sep 9, 2018, 8:56:16 AM
Re: New Build.
The garage floor is actually below the damp coarse level of the house. As you will see in the following image i have used a floor texture to represent a sealed/waterproof finish which curves and continues up the wall 300mm.
Posted by Mike53 at Sep 17, 2018, 10:01:08 PM
Re: New Build.
A few images of the kitchen now :-
After seeing these i noticed a few little tweaks were needed, floating handles mainly, structurally i increased the amount of "return" on the wall with the large hatch, this is to give sufficient surface to support a lintel, changed the doors and drawer fronts to shiny and most importantly modified the island to incorporate a stool, now "she that shall be obeyed" has somewhere to sit whilst working hard - waiting for the dish washer to finish.
For this final image i changed the setting to Gloss and following Cec's and OK's very interesting discussion about settings you will see that this render was taken at 9 AM with the moonlight streaming through the north facing windows. It took nearly 8 hrs on my little PC, but i am quite pleased with it.
Posted by TommoLeo at Sep 18, 2018, 10:54:24 PM
Re: New Build.
It's so cool seeing this process of building the house, Mike! And the bathroom e and kitchen are very well done, how do you make this kind of spot lights in the bathroom ceiling? It seems to work pretty good for lighting a room :)
Posted by Mike53 at Sep 22, 2018, 11:06:14 AM
Re: New Build.
Hi Tommo
The spotlight i use i got from a file that i think Cec shared some time ago in a bathroom file, i'll dig it out and post a link.
I usually set it to about 5% and position a light source approx 200mm dia. below it, height and power of the source varies with what i am trying to achieve.
As the lamp is a light source i cannot import it to the library, i just keep it in a file that's handy and copy/paste whenever i need it.
Posted by Mike53 at Sep 22, 2018, 12:27:00 PM
Re: New Build.
link
Posted by Mike53 at Sep 23, 2018, 1:33:32 PM
Re: New Build.
The sunroom is now complete here are 2 images
Posted by Mike53 at Sep 23, 2018, 1:42:49 PM
Re: New Build.
Oops forgot one.
Here is an image of the kitchen with the new bevel edged worktops
The 2 small worktops have cylinders and spheres for edging, the islands worktop and the main worktop were made with sketchup.
Posted by Ceciliabr at Sep 23, 2018, 1:47:23 PM
Re: New Build.
Very nice!
Perfect renders.
cec
Posted by TommoLeo at Sep 24, 2018, 4:40:38 AM
Re: New Build.
Thanks Mike, I'll use your tips in my future renders a lot!
Beautiful renders in the sun room, can't wait to see the whole house interiors.
Leo
Posted by pwtt007 at Nov 2, 2022, 11:19:01 PM
smile   Re: New Build.
Hello and it's great to see what can be done with time. Congratulations.
I am wanting to design a chicken coop, and base it on timber posts etc. Looking at your house design/build, how/where did you get the timber trusses, beams, post etc ? My library is clearly limited and I am seeking help.
Timber posts, beams,
Chicken wire,
etc.
Thanks in advance,
Peter.
Posted by Keet at Nov 3, 2022, 7:51:06 AM
Re: New Build.
The Dimensional Lumber library might be what you are looking for.
Posted by pwtt007 at Nov 6, 2022, 10:15:18 PM
Re: New Build.
Many thanks Keet, Yes, this is what I need. Wish me luck. I'm just a beginner, but I might post my coop design when done. Peter
