Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) |
| Print at Sep 27, 2026, 10:00:18 AM | |
| Posted by YGYL at Sep 17, 2018, 1:03:23 PM |
Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)The length of objects such as railings or benches is not fixed. It is very painful to draw a suitable railing. There are several ways but they are not perfect 1Tensile deformation 2Exceeded part cannot be cut 3Tensile deformation It takes a new system to paint the railings easily. Pre-segmented dynamic object system!!!! Define parameters by changing part of the name in the model editing software After pre-segmenting the 3D model .After the user changes the length of the object, the model is combined by software calculation!!! The model is divided into 3 parts. Combine these parts according to different situations Combine these parts according to different situations Download the SH3D file on this web page |
| Posted by harbinger at Sep 17, 2018, 5:15:22 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) IDK if SH3D could ever do this, though i could see multiple uses for this concept — stairs, wall sections, windows sets, etc. Would take a lot of programming and testing. But i'd love to see this. |
| Posted by YGYL at Sep 18, 2018, 12:55:11 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) Another structure LAN_GAN2.sh3d ![]() |
| Posted by YGYL at Sep 18, 2018, 7:11:57 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) LAN_GAN3.sh3d ![]() |
| Posted by YGYL at Sep 20, 2018, 9:58:01 AM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects) In this case, two new definitions, patterns and corners have been added. LAN_GAN4.sh3d ![]() |
| Posted by YGYL at Sep 20, 2018, 8:25:59 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)In complex situations, multiple patterns are required and the sequence ID number is used. LAN_GAN5.sh3d ![]() |
| Posted by YGYL at Sep 25, 2018, 4:11:37 AM |
Ceiling gypsum line includes internal corner and exposed corners Ceiling gypsum line includes internal corner and exposed corners download file Ceiling_gypsum_line.sh3d I hope WE can draw a line and calculate it automatically. |
| Posted by VeroniQ at Sep 25, 2018, 5:23:12 PM |
Re: Ceiling gypsum line includes internal corner and exposed corners Thank you, YGYL, for all these interesting models! |
| Posted by YGYL at Sep 26, 2018, 7:09:15 PM |
Re: Ceiling gypsum line includes internal corner and exposed cornersThank you, YGYL, for all these interesting models! Give Puybaret the material to test new functions. it takes a lot of time to do these things. |
| Posted by YGYL at Sep 26, 2018, 7:54:22 PM |
Luxurious ceiling gypsum line!!!!!Luxurious ceiling gypsum line Download the file Luxurious_ceiling_gypsum_line.sh3d Rendered graph Model component layout The whole object consists of small objects. Small objects consist of smaller objects. Smaller objects consist of the left and right sides of the component. The whole object seems to be encoded. The advantage is that it greatly reduces the disk footprint of files, whether they are furniture libraries or SH3D files. After encoding and subtracting edges, the current file is at least 10 times smaller than the original file.Luxurious_ceiling_gypsum_line.sh3d file size is only 3.2MB!!! It’s not for you to compress the file size of each piece of furniture to the limit, it is for you to support the user or the furniture library creator to split the compressed furniture. Without a good method of compressing file size, there will be no good furniture library, without a good furniture library, the user experience will not be good. I have said this before, the user's group furniture can be saved to the furniture library file. When you want to use it, just drag it from the furniture bar on the left side of the main interface to the floor plan. If you can dynamically create complex coded group objects, that's the best thing to do. I think a lot of professionals are going to use Sweet Home 3D. |
| Posted by YGYL at Sep 26, 2018, 8:21:18 PM |
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)Pre-segmented dynamic object system is like this GIF picture. gif file |
| Posted by YGYL at Sep 27, 2018, 4:29:07 AM |
Water pipes and electric wiresWater pipes and electric wires Download the file Water_pipes_and_electric_wires.sh3d 2D vertical 2D view 3D view 3D detail ![]() |
| Posted by bdfd at Sep 27, 2018, 7:41:13 AM |
Re: Water pipes and electric wires Water pipes and electric wires Hi,... Good idea ! In France, all electric network is in the ceiling. It's easier to access and it avoids flooding … . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by YGYL at Sep 27, 2018, 12:17:49 PM |
Woods and grass Woods and grass Download the file Woods_and_grass.sh3d 2762 grass objects with different directions and sizes 2D top view 3D view Trees with different directions Rendered graph |
| Posted by YGYL at Sep 27, 2018, 12:30:05 PM |
Re: Woods and grass If you don’t have a random distribution system, it takes a lot of time to do this kind of map. If you can randomly distribute the specified multiple objects, including Random location within range Random size within range Random direction or both directions Range random machine height Well, doing this is very fast. |
| Posted by YGYL at Oct 13, 2018, 12:14:21 PM |
Re: Woods and grass My thoughts on Pre-segmented dynamic object system's custom user interface Allow advanced user defined material library It also provides ordinary users to define him in software. This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions. The whole process is reflected in a Script form. The software executes some items on the table down. If set correctly, those cases in my front post will be reached. After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects. Script form Type is the most important column.Determines the function of this script.Other columns are his parameters. left Middle (simple) Pattern 1 Pattern 2 Pattern 3 Right corner Inner corner Outer corner Random placement (square) Random layout (circle) Several choices 1 (Book) Intermittent repetition blank |
| Posted by VeroniQ at Jan 29, 2019, 11:01:18 PM |
Re: Woods and grass Thank you very much, YGYL, for these models that I may use in a “Haussmanian” flat. Could you confirm that the 3D models listed on this page are available under Free Art Licence or CC-BY Licence? Thanks in advance |
| Posted by Bubblobill at Jun 22, 2019, 8:39:32 AM |
Re: Woods and grass I've been considering something similar based on a staircase constructing plugin. |
Current timezone is GMT Sep 27, 2026, 10:00:18 AM |
