Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: cylinder mod? |
| Print at Oct 18, 2026, 9:21:23 PM | |
| Posted by Mike53 at Sep 18, 2018, 10:16:12 PM |
cylinder mod? Does anyone know if its possible to make the cylinder, available from the library, into a circle? |
| Posted by Mike53 at Sep 18, 2018, 10:21:07 PM |
Re: cylinder mod? Ring is probably a better description than circle. Mike |
| Posted by hansmex at Sep 22, 2018, 8:42:05 AM |
Re: cylinder mod? Mike, The cylinder from the library is defined in three parts. If you make top and bottom invisible, you are left with a ring. Note that the wall thickness will be zero. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Mike53 at Sep 22, 2018, 10:54:29 AM |
Re: cylinder mod? Thx for the reply Hans, not quite what i wanted, :- cylinder 40mm diameter 1.2m long, then give it an arc 180 degrees (like a wall) and put 2 together - Ring. Could not figure anything out with sh3d so i used sketchup. It was to be used as a round edge on a worktop, the island in my last kitchen thx again m8 Mike |
| Posted by Mike53 at Sep 22, 2018, 10:56:15 AM |
Re: cylinder mod? Maybe put the idea of an arc for the box and cyl in wish list ???? |
Current timezone is GMT Oct 18, 2026, 9:21:23 PM |
