Print at Sep 26, 2026, 4:56:49 PM
Posted by stef.salmon at Sep 28, 2018, 4:24:34 PM
Draw Round Column
This has probably been asked before...how can I draw a small circle to use as a column?
Why isn't there a tool to draw circles and ellipses?
Many thanks.
Posted by ndorigatti at Sep 28, 2018, 4:47:26 PM
Re: Draw Round Column
You can use cylinder object!
Posted by stef.salmon at Oct 4, 2018, 9:17:22 AM
Cylinder object from where?
Posted by bdfd at Oct 4, 2018, 9:44:37 AM
smile   Re: Draw Round Column
It's a standard object made by Emmanuel ! wink
Posted by hansmex at Oct 4, 2018, 10:07:44 AM
1 - draw two walls which start and end at the same coordinates.
2 - give one wall an arc of 180 degrees, the other of minus 180 degrees.
or look here
Posted by Puybaret at Oct 4, 2018, 10:29:42 AM
The cylinder object can be found in the Miscellaneous category.
Posted by stef.salmon at Oct 4, 2018, 10:57:02 AM
Perfect...thank you all for your replies smile
