Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error when open sh3d: Room points must containt at least two points |
| Print at Aug 30, 2026, 8:15:22 AM | |
| Posted by abracadabuda at Nov 5, 2018, 2:49:42 PM |
Error when open sh3d: Room points must containt at least two points Hi, I have problem opening file that I edited with AdvancedEditing plugin. I tried to open it with java console, and here is the error: java.lang.IllegalStateException: Room points must containt at least two pointsI tried to remove the plugin from Sweet Home 3D folder, but the error still occurs. Is it possible to recover the file? Thanks in advance, Matus |
| Posted by Puybaret at Nov 5, 2018, 10:46:40 PM |
Re: Error when open sh3d: Room points must containt at least two points I don’t think it will be difficult to repair your file. If you know XML, you just have to remove the <room> element that contains 2 or less <point> children in the Home.xml entry of your SH3D file. If this sounds too complicated for you, send it to me. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by abracadabuda at Nov 6, 2018, 9:00:46 AM |
Re: Error when open sh3d: Room points must containt at least two points Great it worked! For others: You have to unzip the sh3d file, remove the fault <room> element from Home.xml as Emmanuel wrote, and zip it back to sh3d file. Emmanuel, thanks a lot. Matus |
| Posted by Puybaret at Nov 6, 2018, 9:24:43 AM |
Re: Error when open sh3d: Room points must containt at least two points It's great you could achieve it by yourself! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 30, 2026, 8:15:22 AM |
