Print at Aug 30, 2026, 5:38:20 AM
Posted by basvanh at Nov 24, 2018, 8:55:27 PM
confused   Import set of objects
Hello,
I would like to design a kitchen. I have found a set of kitchen cabinets which I would like to import into SH3D. I have downloaded it as an Collada File. I have imported the object as a single furnature. When I drag it onto my drawing, its a single object with all the caibinets. How can I import it and use al its cabinets/object seperately?
The 3d set: https://3dwarehouse.sketchup.com/model/71fa3d...36d93/Kitchen-Cabinet-Set
Thank you in advance, regards,
Bas
Posted by hansmex at Nov 24, 2018, 11:51:41 PM
Re: Import set of objects
1 - install SketchUp
2 - open your kitchen file
3 - delete all models except one
4 - export your model
5 - use Undo to restore all models
6 - repeat steps 3 to 5 until all models are exported
Good luck!!
Posted by Puybaret at Nov 24, 2018, 11:53:12 PM
As I’m not sure that the free version of SketchUp will allow you to export a file at Collada format, I would import it in Blender which will let you export to OBJ or Collada formats only the selected object.
Posted by hansmex at Nov 25, 2018, 12:29:09 AM
Install SketchUp 2015, last free version with export.
Posted by basvanh at Nov 25, 2018, 3:58:49 PM
Got it working with SketchUp 2015, thanks !
