Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: raising existing walls and ceiling |
| Print at Oct 15, 2026, 4:42:47 AM | |
| Posted by bigjim33 at Dec 5, 2018, 5:08:41 PM |
raising existing walls and ceiling hello to all, I started to draw a project without noticing that the wall height is set to 250cm instead of 290cm. May I raise all the existing walls and the ceiling to 290cm at once? thanks, Marco |
| Posted by VeroniQ at Dec 5, 2018, 7:26:05 PM |
Re: raising existing walls and ceiling Hello Bigjim. Select your whole design in Plan with Ctrl A (or cmd A on masOS), then Plan > Modify wall and change the height. Only your walls will be changed. If you have only one level, the ceiling will adjust itself at 290 cm. If you need a level, you can read this blog article . |
| Posted by bigjim33 at Dec 11, 2018, 2:35:08 PM |
Re: raising existing walls and ceiling thank you! |
| Posted by HananeBelyekdoumi at Dec 20, 2020, 7:23:08 PM |
Re: raising existing walls and ceiling Is there a way to raise the walls in the online version of sweet home 3d? I was also wondering if there is a way to put a roof in the online version. |
| Posted by Puybaret at Dec 20, 2020, 10:04:07 PM |
Re: raising existing walls and ceiling The Online version isn’t finished, and you’ll have to be patient before these features become available. If you need them, I would suggest to export your online design and modify it with the installer version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 15, 2026, 4:42:47 AM |
