Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: PhotoVideoRendering-1.6 crashes |
| Print at Sep 25, 2026, 7:35:19 PM | |
| Posted by svedel77 at Dec 9, 2018, 6:49:43 AM |
PhotoVideoRendering-1.6 crashes Hi, When rendering a movie using PhotoVideoRendering-1.6 plugin, SH3D crashes after a few minutes. No errorcode or description. It just crashes. This is if I render in 1920x1080 pixels. Rendering the same job in lower resolution, SH3d does not crash. Rendering a movie with the built-in renderer, it's not a problem. SH3D version 6.0 PhotoVideoRendering version 1.6 |
| Posted by enkonyito at Dec 10, 2018, 11:18:42 PM |
Re: PhotoVideoRendering-1.6 crashes Hi svedel77, What do you mean by SH3D crashes? It closes? Freezes? For what quality? You can send me your file in private message if it's possible. Enko ---------------------------------------- EnkoNyito |
| Posted by svedel77 at Dec 17, 2018, 10:38:25 AM |
Re: PhotoVideoRendering-1.6 crashes Hi Enko, SH3D closes down, without warning or errorcode. Sometimes after 20 seconds rendering. Other times after several minutes. I've uploaded my project right here : www.pionersoft.dk/jpg/Danavejs.sh3d - Søren |
| Posted by hansmex at Dec 17, 2018, 12:35:25 PM |
Re: PhotoVideoRendering-1.6 crashes Soren, Your image rendered without problems in 52 minutes. Memory usage was around 5-6 GB. Check Help -> About to see how much memory is available for SH3D on your computer. If necessary use the XMX-trick to increase memory. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by svedel77 at Dec 17, 2018, 12:48:54 PM |
Re: PhotoVideoRendering-1.6 crashes OK, I'll look into it. |
Current timezone is GMT Sep 25, 2026, 7:35:19 PM |
