Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Display and print in 3d - Ubuntu 18.4+NVIDIA GEFORCE 930mx |
| Print at Oct 14, 2026, 6:06:56 PM | |
| Posted by Darkthuban at Dec 12, 2018, 2:11:38 PM |
Display and print in 3d - Ubuntu 18.4+NVIDIA GEFORCE 930mx I use S3d in Ubuntu 18.4+NVIDIA GEFORCE 930mx environment. Tried to use the original NVIDIA drivers and the Nouveau one (which by the way works better than the propriety ones) but cannot print in 3d (the option is not selectable in Print Setup). More over I have notice that in MAC/OS it is also possible to view the upper side in 3d, which is very usefull. Infact in the place were you normally design in 2d format, the library objects like furniture, people, and so on are also viewed in 3d format. Below some parm: Sweet 3d version: 6.0 Ubuntu: Ubuntu 18.04.1 LTS Resolution: 1920x1080 pixels OpenGL Renderer: (Unknown) Vendor (Unknown) Renderer (Unknown) Version (Unknown) Direct Rendering No Any hints ? Best |
| Posted by Puybaret at Dec 12, 2018, 6:36:51 PM |
Re: Display and print in 3d - Ubuntu 18.4+NVIDIA GEFORCE 930mx And what about the original NVIDIA drivers? What let you think that they don't work correctly? From your report, the new ones don't seem to work so well... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Darkthuban at Dec 12, 2018, 8:29:17 PM |
Re: Display and print in 3d - Ubuntu 18.4+NVIDIA GEFORCE 930mx I made the test with the Nvidia drivers too, uploading the last updated version for the Geforce 930mx, which is the NVIDIA-Linux-x86_64-410.78.run. Sweet Home 3d was not even able to display correctly the basic functions, leaving portions of the screen totally black. I have also tried with the *390* as suggested by the software updater in Ubuntu, but in that case I had no change at all in the display and print setup. |
| Posted by Darkthuban at Dec 14, 2018, 9:14:44 AM |
Re: Display and print in 3d - Ubuntu 18.4+NVIDIA GEFORCE 930mx Hello, is there any kind of additional info that I should provide ? Many thanks. Best. |
Current timezone is GMT Oct 14, 2026, 6:06:56 PM |
