Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: arch shape roofings |
| Print at Sep 25, 2026, 8:08:36 AM |
| Posted by BASHEER at Dec 14, 2018, 3:34:00 PM |
arch shape roofings anybody can help for creating a arch shape roofing |
| Posted by bdfd at Dec 15, 2018, 6:42:52 AM |
Re: arch shape roofings anybody can help for creating a arch shape roofing Like ? A little real picture would be welcomed… . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by VeroniQ at Dec 15, 2018, 9:17:51 AM |
Re: arch shape roofings I suggest you can build your arch with walls in a new file, then import the arch as an objet with "Export to OBJ format" menu item. Take care to import only the walls. |
| Posted by Billmart at Nov 20, 2020, 2:28:05 AM |
Re: arch shape roofings How do you bend or arch a floor ? ... How do you create a arch shape like a small bridge ? |
| Posted by Puybaret at Nov 20, 2020, 6:57:41 AM |
Re: arch shape roofings You can’t bend a floor. And without a picture, it will be difficult to help you more, as alrealdy suggested. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Nov 20, 2020, 10:21:19 AM |
Re: arch shape roofings Is this what you are looking for? http://www.sweethome3d.com/support/forum/viewthread_thread,2119 ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Billmart at Nov 21, 2020, 5:07:21 AM |
Re: arch shape roofings Why a wall can not be turn east to west in SH3D ??? |
| Posted by Billmart at Nov 21, 2020, 5:09:09 AM |
Re: arch shape roofings Actually, the question should be ... why a wall can not be turned from horizontal to vertical ? |
| Posted by Billmart at Nov 21, 2020, 5:13:34 AM |
Re: arch shape roofings There's no way to turn a wall from vertical to horizontal in SH3d .... the same as there's no way to bend a wall nor a roof to build a arch surface. If you know a better way to achieve such task, let us know since I'm not the only one asking that question. |
| Posted by Puybaret at Nov 21, 2020, 7:16:53 AM |
Re: arch shape roofings Billmart, walls are vertical and can’t be leaned in Sweet Home 3D. By the way, please stop polluting other threads with similar questions. That won’t make appear this feature. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 8:08:36 AM |
