Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Staircase. |
| Print at Aug 29, 2026, 2:07:54 AM | |
| Posted by Mike53 at Jan 18, 2019, 10:09:03 AM |
Staircase. Hi This project has, yet again, started with an idea for a staircase, for no other reason than that i enjoy making them. Older styling and quite complex, practical and quieter than just wooden treads. View up the stairs. The treads, risers, rails and newel posts are a mixture of cylinders, walls, boxes and floors, the spindles came from sketchup, then i modified them with an elongated cylinder, unfortunately the cylinder i selected from the library for the spindles and newels is somehow discolored on its lower half, something i did not notice until rendering. Too late to change now. ![]() View from the kitchen door. The door is, again, walls, boxes and opaque walls with handles that i have used with several windows and doors. ![]() When i searched for a dsek i could not see exactly what i wanted. Boxes, walls, spheres and floors were used to create one. ![]() Finally, for a novelty. We nan close the roller. ![]() Mike |
| Posted by Mike53 at Jan 18, 2019, 11:16:47 AM |
Re: Staircase. Here is a link to the file. Just the 1 room to look at though. Comments, critique and question all welcome. MIke |
| Posted by juantonio at Jan 18, 2019, 12:13:15 PM |
Re: Staircase. Hello, A little dark but so british ! Nice style. |
| Posted by Mike53 at Jan 18, 2019, 12:25:28 PM |
Re: Staircase. Thank you juantonio, all the renders are done set at midnight with a 600mm daylight source outside, set to 80%, ceiling lamps are set to 8% and AEB box is checked. Updated Link Mike |
| Posted by Mike53 at Jan 21, 2019, 5:23:35 PM |
Re: Staircase. Made a few changes to this staircase... then changed the decor.....then changed the room. Other than that this is the some room... ![]() Hopefully a welcoming warmth. Mike mmmm..... maybe it needs a rug..... |
| Posted by Mike53 at Jan 21, 2019, 10:43:42 PM |
Re: Staircase. Decided against a rug so... Made up a fitted carpet instead. ![]() Mike |
| Posted by VeroniQ at Jan 22, 2019, 7:20:22 AM |
Re: Staircase. Smart et very realistic, Mike! |
Current timezone is GMT Aug 29, 2026, 2:07:54 AM |
