Print at Sep 25, 2026, 7:12:37 AM
Posted by Vuemme43 at Jan 21, 2019, 9:08:03 AM
Single-glazed glass door for a store
I can not find the SweetHome 3D model of the single-glazed glass door for access to a store, can you help me?
Posted by VeroniQ at Jan 21, 2019, 9:26:39 AM
Re: Single-glazed glass door for a store
Buongiorno!
I often use this one.
Posted by okh at Jan 21, 2019, 9:26:55 AM
You find some door models in the SH3D Sourceforge repository (a couple of glass ones too). Or, 3D warehouse search for glass door.
PS - an experimental, simple door with hinges in SF 3D models 508.
Posted by Bubblobill at May 4, 2019, 3:12:06 PM
Glass-Door.zip
I made this.
Enjoy
Posted by Mike53 at May 4, 2019, 5:34:25 PM
Thank you for sharing the door Bill, i do like the way you have set up the handles, unfortunately, there is a gap between the frame and the door, when positioned in a wall sweet home 3d will fill that gap with wall, 2 other points of less importance, it is only 800mm tall and it is needs to be imported as a door.
I noticed the issue with the gap because i have done the same sad.
Good luck and hope to see more.
Posted by Bubblobill at May 5, 2019, 2:12:51 AM
Hmmm... I put the air gap in on purpose for accuracy. I suppose I shall just have to take it out.
The whole unit is supposed to be 80" tall based on a commercial spec I found somewhere. Resize to 203cm for correct sizing.
Posted by Bubblobill at May 5, 2019, 2:23:51 AM
New link to file. Closed air gaps between frame and door as suggested by Mike53.
Glass-Door.zip
Posted by Bubblobill at May 6, 2019, 6:13:56 AM
Updated again. Now has a threshhold
Glass-Door.zip
Posted by Bubblobill at May 7, 2019, 7:47:45 AM
I declare this to be the last version I can be bothered with. I even added swing area and stuff.
Enjoy
Glass-Door.sh3f
Posted by Mike53 at May 7, 2019, 5:30:11 PM
Better, but wall still visible, threshold slight issue, flickering, opaque? Even added to library it is still an object not a door, reopen with furniture editor and define as door
MIke smile
Posted by Bubblobill at May 11, 2019, 12:10:47 PM
Flickering threshhold is likely just due to it being thin. It seems to render correctly. As for the wall showing through, I am stumped. I have fiddled with every part of the preferences file to no effect and cannot find any significant fault in the model.
The only thing left I can think of is to create the object as a single shell and see if that works.
