Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Can you tell me what is wrong here? |
| Print at Aug 28, 2026, 11:57:19 PM | |
| Posted by sztui at Jan 21, 2019, 11:33:44 AM |
Can you tell me what is wrong here? Hello! I kjust found this awesome software and i designed a weekend house that could be used for living as well. I really loved working with this plan, but at the end something went wrong, some white bars appeared after i elevated levels. It looks like the doors interfere with something. Can you please tell me what is wrong? You can download the plan here. Thank you! |
| Posted by Mike53 at Jan 21, 2019, 1:29:41 PM |
Re: Can you tell me what is wrong here? I think if you replace the huge wall on the lowset level wit a triangle from the library you will be ok. Mike |
| Posted by FDpaffie at Jan 21, 2019, 2:57:02 PM |
Re: Can you tell me what is wrong here? that is working. and lowering the wall where the house is standing on by 1 cm will help fixing the floor inside ,its coming trough the floor ---------------------------------------- To Draw or not to Draw ...... Thats nolonger a question .. We draw |
| Posted by sztui at Jan 22, 2019, 1:16:13 AM |
Re: Can you tell me what is wrong here? Oh thank you guys! It's working. Why is there difference between triangle wall and object triangle? |
| Posted by Mike53 at Jan 27, 2019, 4:28:09 PM |
Re: Can you tell me what is wrong here? I noticed recently, in 2 of my projects, that when positioning a door or window above an angled wall there is a tendency for the "cutout" to drag the angled wall up. I did not know myself why this was but OKH came up with a good solution and Emmanuel explained it, i think that was happening for you. Mike |
| Posted by Puybaret at Jan 28, 2019, 11:06:04 AM |
Re: Can you tell me what is wrong here? Using the new version 6.1 would fix your issue too. Why is there difference between triangle wall and object triangle? Doors and windows can make holes in walls, not in triangles. But until version 6.0, openings placed at an elevation between the bottom and the top of a sloping wall had also some parts under them like in your file (see thread #9104).---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 28, 2026, 11:57:19 PM |
