Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: modifying a wall |
| Print at Sep 24, 2026, 10:07:12 AM | |
| Posted by spluongo at Mar 1, 2019, 8:08:36 PM |
modifying a wall Hi. I'm a new user with a very basic question. I'm trying to modify a wall for a dead-end room at the end of a hallway -- no door or doorway. Each time I try to shorten, ie, elminate a section of, the affected wall, SH3D brings the corner of the room and the adjoining wall with it. I'm sure the answer is simple, but it's got me stumped. I built my house floorplan by first using "create rooms," then selecting "create walls" and double clicking. Erlier, I sucessfully removed some other wall sections in the plan, but can't recall what, if anything, I did differently. Thanks. |
| Posted by hansmex at Mar 2, 2019, 8:14:49 AM |
Re: modifying a wall If you use "create walls" then all walls are connected to each other. If you move a wall or a corner, the connected wall(s) move also. Use "split wall", then delete one half, and resize the other half. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by spluongo at Mar 2, 2019, 6:14:47 PM |
Re: modifying a wall hansmex...Thanks. That worked well. |
Current timezone is GMT Sep 24, 2026, 10:07:12 AM |
