Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Select Hide Utility plug-in |
| Print at Sep 23, 2026, 4:35:03 PM |
| Posted by sjb007 at Aug 19, 2022, 1:20:57 PM |
Re: Select Hide Utility plug-in Hi Dorin, I saw you mention this plugin in another thread and thought "Oh. That sounds useful as I try to deconstruct my plans to try and produce acceptable planning drawings. Unfortunately it does not work for me, although it might just be me. Plugin installed, show an Edit menu item and a tool bar item, but clicking either one does nothing. No error message either. Just nothing. I don't have the conflicting plugin the text mentions, and I'm running latest (7.0j) Have you tested it with 7.0? |
| Posted by Puybaret at Aug 19, 2022, 3:26:39 PM |
Re: Select Hide Utility plug-in I just tested the last version and it doesn't work when there is no level in the home, with the following exception: Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.eteks.sweethome3d.model.Level.isViewableAndVisible()" because the return value of "utility.SelectHidePlugin.access$6(utility.SelectHidePlugin)" is nullDorin, I hope this will help you to fix this bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sjb007 at Aug 19, 2022, 8:41:18 PM |
Re: Select Hide Utility plug-in Thanks Emmanuel. I never even thought to test with a real file. I was just trying to check the plugin out on an new file with a few bits and bobs and never thought to add levels. |
| Posted by dorin at Aug 20, 2022, 11:57:08 AM |
Re: Select Hide Utility plug-in All's of You have right! The fault is mine! So, New version 1.6 . - fix the bug previously mentioned; - add Chinese translation (thanks to YGIL); Reminder: this plugin work ONLY on & with objects at selected level. Also on Source Forge . ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Puybaret at Aug 21, 2022, 10:58:57 AM |
Re: Select Hide Utility plug-in Thanks Dorin, it's possible to select objects in a home with no level now ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 4:35:03 PM |
