Print at Sep 26, 2026, 4:08:49 AM
Posted by davevad at Mar 20, 2019, 12:20:32 PM
Mouse pointer offset
Hi, I have a problem with my mouse pointer. If I select a new project everything is fine. I can create a wall at the crosshair. After creating more walls suddenly the pointer is 100px offset and I can not place the wall within the pointer location. On saved project the same. I try to move things around and on move the things appear x+200, y-100 offset location relative to the crosshair. Someteimes it is even worse. I have unistalled it and reinstalled it. 32 bit 64 bit does not matter. Same problem. I have noticed that the coordinates little pop up is flickering between the real crosshair location and the misslocated position location. Someone same problem or solution ? txh reg
Posted by davevad at Apr 1, 2019, 9:11:35 AM
Re: Mouse pointer offset
Solved. There Problem is caused by the plug-in on sourceforge:
#20 Group furniture items in category
reg
