Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Release w/o JRE |
| Print at Sep 28, 2026, 10:09:03 AM | |
| Posted by Jaroslav_Mazurak at Sep 26, 2007, 8:09:00 AM |
Release w/o JRE Can you release version without JRE bundled also? [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Sep 26, 2007, 9:45:00 AM |
Re: Release w/o JRE Did you see that Sweet Home 3D is also available as a Java Web Start application at http://sweethome3d.sourceforge.net/download.html ? I could build a Jar file without a bundled JRE, but felt that Java Web Start solution was enough and better at this time (a Jar file may be run with a double click, but you don't get file extension associations and program icon). Why would you need such a Jar file ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Randal_Lovelace at Mar 8, 2008, 8:48:00 AM |
Re: Release w/o JRE Part of the installation problem seems to be the whole .jar thing... Most 'users' aren't 'that computer savvy, so why make it complex. You've made a nice .exe for WINDOWS USERS... why not make a .rpm for Linux? |
| Posted by Puybaret at Mar 8, 2008, 8:37:00 PM |
Re: Release w/o JRE > Why not make a .rpm for Linux? There's no special reason. It's just I thought the .tgz file is easy to unzip *and* to uninstall (in case of ;-). Before changing, I would like to be sure that Linux people are more used to install .rpm files... BTW, would you have a link to a nice and short .rpm builder tutorial ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Mar 8, 2008, 9:11:00 PM |
Re: Release w/o JRE I found this in LinuxQuestions.org: http://www.linuxquestions.org/questions/susen...4066/?highlight=build+rpm I know this is for SuSE but there should be a buildrpm package for your system. Anyway, it refers to this tutorial from Novell: http://en.opensuse.org/SUSE_Build_Tutorial |
Current timezone is GMT Sep 28, 2026, 10:09:03 AM |
