Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: scale up 3D view? // 2 homes .. to bring together? |
| Print at Oct 6, 2026, 11:20:39 PM | |
| Posted by TinaK at Apr 3, 2019, 9:56:06 AM |
scale up 3D view? // 2 homes .. to bring together? hello together, I'm new and I'm trying to create my new loft with this program ;) and I have two questions: 1. I made the error to create two homes instead one with different rooms... so - Is there a possibility to bring together this two rooms in one home? 2. At one home at 3D view the view is really big, at the other home the 3D view is very small size - how can I make it bigger? THANKS for your help! |
| Posted by Mike53 at Apr 3, 2019, 11:32:55 AM |
Re: scale up 3D view? // 2 homes .. to bring together? Could you copy/paste from 1 to the other. Not sure about the size of the view, check the viewer position for each and that both are on either arial or virtual. Mike |
| Posted by TinaK at Apr 8, 2019, 7:25:36 PM |
Re: scale up 3D view? // 2 homes .. to bring together? Hello Mike53, thanks for answer.. but HOW can I copy/paste? Is it a need to copy/paste every single furniture and so on or can I do it at once? |
| Posted by Mike53 at Apr 9, 2019, 12:08:11 AM |
Re: scale up 3D view? // 2 homes .. to bring together? All at once , left click and drag the mouse over, or right click >select all, or you could hold the ctrl key and select as many as you wish. i would suggest you copy 1 item across first, compare its location when sited in the other room and use the "move" tool to position, remember the x and y values you move it, these can then be used to move all the other items. Mike |
| Posted by TinaK at Apr 9, 2019, 4:46:31 PM |
Re: scale up 3D view? // 2 homes .. to bring together? many many thanks! It worked! |
Current timezone is GMT Oct 6, 2026, 11:20:39 PM |
