Print at Oct 2, 2026, 12:19:09 PM
Posted by pencilart at Oct 2, 2007, 4:37:00 PM
How Do I run this?
I extracted the .tar file but I cannot find any executable to run the program.
I have it placed in /home/<username>/Apps/SweetHome3D-1.1 but like I said, there's no way to run it! What do I click on to run it? Where's the script?
I thought this was for endusers who want to design homes.
[Note: this thread was started on sourceforge.net forums]
Posted by Puybaret at Oct 2, 2007, 7:35:00 PM
Re: How Do I run this?
If you are under Ubuntu, double-click on SweetHome3D-1.1 file and click on Launch (or Run) button.
On other Linux systems, open a terminal, go to SweetHome3D-1.1 directory with command "cd", and run the command "./SweetHome3D-1.1"
It is, but there are too many configurations available for Linux, so I can't test each of them.
If you know a better way to run Sweet Home 3D on your Linux box, please share it here.
Posted by pencilart at Oct 2, 2007, 8:22:00 PM
ok, what worked was just to type ./SweetHome3D without the -1.1
Thanks!
Posted by Puybaret at Oct 2, 2007, 10:28:00 PM
Sorry, I forgot that the command was SweetHome3D and not SweetHome3D-1.1. ;-)
Posted by Randal_Lovelace at Mar 9, 2008, 12:16:00 PM
Best method for Linux users is what are known as installers. For Red Had based Linux (including Mandriva) these are .RPM http://www.rpm.org/ <- that page should contain all links to everything you ever wanted to know about them, and how they work. For Debian based Linux (including Ubuntu/Xubuntu/Edubuntu and many others) .DEB is the preferred installer. I don't see an information page about .deb format but can give a link to http://www.debian.org/intro/about for you to learn more about Debian itself.
Posted by pencilart at Mar 9, 2008, 3:48:00 PM
Hey Randal, nice to see you posting here.
~~ Gymnart on dA.
Posted by Randal_Lovelace at Mar 14, 2008, 9:35:00 PM
Well, I managed to upload the doors, and pybaret then downloaded them and made them in two different colors and reuploaded them :D
I still can't run this on my computer no matter how I try and at this point I've tried a lot of different things. My thing is if I can run OpenGL, and inbrowser Java - then why won't this program work (or for that matter those Java test things :D)
Posted by pencilart at Mar 14, 2008, 9:41:00 PM
I'm wondering the same thing.
Are there any missing Java packages, maybe? Do you have every Java package that is available for your system (and that is compatible with it)? I wouldn't know what to look for though.
