Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Desktop shortcut? |
| Print at Sep 28, 2026, 9:16:32 PM | |
| Posted by pencilart at Oct 2, 2007, 9:51:00 PM |
Desktop shortcut? Can I make a desktop shortcut so I won't be having to open the terminal every time I want to run SweetHome3D? [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Oct 2, 2007, 10:32:00 PM |
Re: Desktop shortcut? You can view SweetHome3D file content : it is just a command that should be run inside SweetHome3D-1.1 directory. Maybe, renaming it as SweetHome3D.sh should make it double-clickable. Which system are you using ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Oct 2, 2007, 10:41:00 PM |
Re: Desktop shortcut? I'm using SuSE 10.0 and KDE for my desktop environment. |
| Posted by pencilart at Oct 2, 2007, 10:45:00 PM |
Re: Desktop shortcut? P.S. I renamed SweetHome3D like you said but that did not work. |
| Posted by Puybaret at Oct 2, 2007, 11:33:00 PM |
Re: Desktop shortcut? In Konqueror, try Create New File->Link To Application... See http://docs.kde.org/stable/en/kdebase/konqueror/making.html ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by pencilart at Oct 3, 2007, 7:04:00 PM |
Re: Desktop shortcut? ok, I finally got that to work. I had forgotten about the ' that should surround the path. I also had to put the path in the work path area. Thanks!! |
| Posted by jw_e_dan at Oct 3, 2007, 8:48:00 PM |
Re: Desktop shortcut? Why plenty of "Help" messages from sweet home 3D users appeared on my mailbox?! I'm not the person who created this software! So HELP! my mailbox is full of messages I'm not concerned with! |
| Posted by Puybaret at Oct 3, 2007, 8:53:00 PM |
Re: Desktop shortcut? You probably subscribed to this forum. In the messages you received, there should be a link to unsubscribe to Help forum. Simply, click on it ! ;-) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 9:16:32 PM |
