Sweet Home 3D Forum » List all forums » » Forum: Forum en français » » » Thread: Problème de lumière. |
| Print at Aug 28, 2026, 7:11:27 PM |
| Posted by SARRAVAL at Apr 24, 2019, 8:09:36 AM |
Re: Problème de lumière. Love this room, looking forward to more. Thank you very much, it's a pleasure, when someone appreciates your work. ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 24, 2019, 4:12:20 PM |
Re: Problème de lumière. Quelques corrections ![]() Je n'ai pas encore mis en rendering la console retourné , mais ca arrive , le calcul est très long !!!!! ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by Mike53 at Apr 24, 2019, 7:26:07 PM |
Re: Problème de lumière. I have a suggestion for your ceiling/lighting, would you mind if i posted a small image as explanation? |
| Posted by SARRAVAL at Apr 24, 2019, 7:46:14 PM |
Re: Problème de lumière. It does not bother me at all on the contrary I am eager to learn. ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by Mike53 at Apr 24, 2019, 7:55:51 PM |
Re: Problème de lumière. My sentiments exactly. You have positioned light sources in the corners, the reason is understandable, but there does not appear to be anywhere for that light to come from. I propose a modification to the molding arrangement, if it can be done with this molding, Here is my suggestion. ![]() It is only a thought, easily discarded, but it may help. |
| Posted by SARRAVAL at Apr 25, 2019, 8:07:35 AM |
Re: Problème de lumière. I'll try this option, and I'll keep you up to date. ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 25, 2019, 4:25:37 PM |
Re: Problème de lumière. Voila: ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by Mike53 at Apr 26, 2019, 6:20:42 PM |
Re: Problème de lumière. An impressive room, but still room for improvements, hopefully. There is a File here that might be able to help. I did not want to flood your topic, so the file contains 4 images. Each is a replica, close, of your room, illuminated in 4 different ways. 0 and 1 show "normal" light sources, 3 and 4 are using Enkinyito's latest beta 1.7 rendering plug-in, which you will need should you decide to replicate it, The .rar file also contains the sh3d file i used to create the images. None of them are intended as cut/paste solutions, but to give you an idea of what could be achieved. From the file i hope you will be able to illuminate your room to your satisfaction using some of the info, heights, elevations, power settings etc. Ignore the sources near the french doors, that was a separate test. Good luck. Mike |
| Posted by bettycc at Apr 26, 2019, 6:35:18 PM |
Re: Problème de lumière. Moi je ne trouve pas joli ces luminaires dans cette pièce |
| Posted by Puybaret at Apr 26, 2019, 10:50:04 PM |
Re: Problème de lumière. Tous les goûts sont dans la nature ! Moi, je trouve ces luminaires très sympas et ils rendent même étonnement bien. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 28, 2026, 7:11:27 PM |
