Print at Sep 30, 2026, 4:08:25 AM
Posted by Mike53 at Apr 22, 2019, 11:05:42 AM
Volunteer needed....
Would anyone like to volunteer to sort out the mysterious world of a staircase cut out for me, i can email whatever info you may need and, of course, the object file.
Thx in advance
Posted by bdfd at Apr 22, 2019, 6:50:25 PM
Re: Volunteer needed....
Hi Mike,
Here is my answer with 2 solutions.
It is impossible to simply answer your request.
However, there are 2 solutions.
1. it is necessary to move back the arrival wall on the first floor (1) to hide the hole and add a box at the top and on the same level (2) as the last step height = 2500mm and thickness = 2950mm
2. the design of the stairs must be reviewed so that the clearance step is at the same level (seen from above) as the last step from the top.
In these 2 cases, the hole will disappear.
I hope that it's OK for you.
wink
