Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: New SH3D install doesn't work |
| Print at Aug 28, 2026, 7:13:30 PM | |
| Posted by DerekvG at Apr 22, 2019, 11:59:14 AM |
New SH3D install doesn't work Downloaded latest version SH3D 6.1.2 from this website and expanded archive in /etc/sh3d on my ubuntu 18.1.2 LTS laptop Couldn't start the application nor could the java version. Then moved the directory to /usr/share/sh3d apllication doesn't start a) what did I do wrong /omit to do during install b) is there a verbose/debug mode form terminal such that i can see error messages? |
| Posted by DerekvG at Apr 22, 2019, 12:09:34 PM |
Re:
New SH3D install doesn't work starting the application from the command line in terminal results in Command not found d---@---Ubuntu:/usr/share/SweetHome3D-6.1.2$ dir COPYING.TXT THIRDPARTY-LICENSE-ITEXT.TXT jre8 THIRDPARTY-LICENSE-JAVA3D.TXT lib THIRDPARTY-LICENSE-JAVA.TXT LICENSE.TXT THIRDPARTY-LICENSE-JEKSPARSER.TXT SweetHome3D THIRDPARTY-LICENSE-JMF.HTML SweetHome3DIcon.png THIRDPARTY-LICENSE-SUNFLOW.TXT SweetHome3D-Java3D-1_5_2 THIRDPARTY-LICENSE-TANGO.TXT THIRDPARTY-LICENSE-BATIK.TXT THIRDPARTY-LICENSE-VECTORGRAPHICS.TXT d---@---Ubuntu:/usr/share/SweetHome3D-6.1.2$ SweetHome3D SweetHome3D: command not found |
| Posted by dorin at Apr 22, 2019, 4:20:12 PM |
Re: New SH3D install doesn't work Wrong is the place where You expand the archive. You don't need to be root to run this program. Expand it as user in Your home folder (autodetect folder option); In the newly created folder double click on SweetHome3D file and chose Execute. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Puybaret at Apr 22, 2019, 7:29:36 PM |
Re: New SH3D install doesn't work From the command line, you should add ./ in front of SweetHome3D : ./SweetHome3D---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 28, 2026, 7:13:30 PM |
