Print at Oct 8, 2026, 6:26:07 AM
Posted by runlevel6 at May 6, 2019, 5:02:56 AM
For the love of all...WTH....
I have been using this software for the past few weeks. Suddenly, on a printout where I chose to send the 3d view to a seperate window, it is impossible to revert to having the 3d model back to the default view...under the 2d view.
What is worse is that if I try to close the 3d window, all of the program becomes completely un responsive. All I can do is kill java in the task manager. to close the program, where it will re-open with the 3d view in a different window.
Posted by runlevel6 at May 6, 2019, 3:26:44 PM
Re: For the love of all...WTH....
Additional Info:
When I open the Sweet Home program, it automatically opens with the previous file (instead of opening the program itself)...and the title bar reads the filename "Kitchen.sh3d[recovered]".
I never specifically asked it to recover files, nor does it allow me to close the file...any attempt to work with it just locks the program up.
Is there a way to flush out what is locked up short of re-installing the program? I dont want to have to track down all the custom components i loaded into it again.
Posted by runlevel6 at May 6, 2019, 3:42:38 PM
OK, I have success:
When the "recovered" file opens...DONT DO ANYTHING WITH IT! Go File > Save As... > and save as a completely different file. Then File > Close.
Any attempts to work with the recovered file will lock everything up.
Posted by Puybaret at May 13, 2019, 11:46:56 AM
The recovered file is sometimes buggy itself, in some rare cases. You can also remove it from the recovery subfolder found in private Sweet Home 3D folder (C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D under Windows).
